Dumbass question
Man of Honour
Man of Honour
18 Oct 2002
Cotswolds
I have a DS4 with an E6300 @ 3.01ghz. I'm still running F5 Bios as I just haven't been arsed to update it :o
Quick question, will updating the BIOS reset everything to default?
phil14 said:
if it works and its good just leave it is what i say..
Yeah I probably will just leave it TBH. It's rock solid stable at 3.01ghz with nice temps, so if it aint broke...........
Big.Wayne said:
Whats your temps like?
~45 idle, 56 loaded (Coretemp). Speedfan reports around 12 degrees less for both. I'm at 1.35v, and using a Scythe Infinity with AS3.
Yeah sounds fine, a bit warm at idle but nothing to worry about. I got the same chip, same 1.35v and that takes it to 3150MHz
I'm 95% sure my chip has a bad fitting between the IHS and the CPU slug!
