Dumbells to travel
11 Dec 2004
Hi all,
Going away for a while, I have some dumbells but they are quite old and bulky.
Looking for a pair of new ones that would be better for traveling, the others are more than good enough for what I need at home.
No other more specific reqirements really, any suggestions?
Cheers
What weight dumbbells do you want? And do you want ones that you can adjust by adding more weights to the dumbbell bar (spinlock) or the other type that is at a fixed weight? :)
Nah I dont want fixed ones, Ideally something that does a weight range around about the 10kg mark.
The weight isnt a problem to take as im going by car, but space really is at a premium
