I thought a dump to atmos or recirculating valve was to expel excess pressue when you come off power. This stops the turbo stalling. If you didn't have one of these, your turbo would stall every time you change gear meaning that on every gear change, you turbo would have to spool up again.Lowe said:As for dump valves being needed, cos your turbo will die - this is utter tripe. Unless you're running serious, serious boost this isn't the case. Dump valves kill your throttle response, since the turbo has to spool up again from scratch. When the system has boost in it because it's harder to leak away, your throttle response is a lot sharper. Dump valves are there for show and to turn heads. Recirc valves are used to quieten the car down.![]()
As above, I think all turbo's cars will have a 'dump valve', only they will be a recirculater, so you wont hear any 'tsst'. Plus an auto would be less aggressive on the gear changes, so you're less likely to make it do so much.Stonedofmoo said:Can you actually have a dump valve on a automatic?
I cant think of an automatic that had one
Stonedofmoo said:Nah Ford never fitted a dump valve of any type on the RS Turbo's and i'm sure other cars with smaller turbochargers such as the Smart cars dont have one either. There's simply no point when such little boost is involved.
And turbos dont get much smaller than that!vanpeebles said:all depends on the car! mine has a factory fitted recirc that i changed to a hks bov
Bug One said:Admittadely, I only have first hand experience with my current turbo'd car, but I'm pretty sure all manufacturs put a recircuating dump valve on them as standard. I dont think they would do that if it wasn't nessecary, or at least beneficial to the car.
Have you actually removed the recirc?Bear said:When I fitted a FMIC, my recirc packed in for some unkown reason and have been running 15psi and then 17psi without any problems without the recirc working.
