Dungeon Defenders
OcUK Staff
12 Apr 2008
OcUK HQ
I am a Squire, what tips have you got? I have been playing locally. :)
Also, leaving mana/weapons on the floor after the rounds do they automatically get picked up, or do you have to collect everything?
if u leave mana it goes straight to your bank, items that are left are sold and the mana goes to your bank.
cant help with squire really as i dont play one yet.
edit, well i do know that a barrier with a cannon ball tower or 2 behind it is a pretty good defence, especially when upgraded to max. :) spinning tower are good @ choke points too.
Naughty moderator, not using the existing thread.
Anything on the ground is auto-sold at the end of a wave and shared between all players.
Squire can be played either as a hero or tower character, but personally I'd say they're more beneficial as a tower hero. The health the barriers have at high levels can get rather silly :D
As already said, items at the end of the wave will get automatically sold and then the mana is automatically added to your bank - however with any mana gems I am not sure and always have been curious - I thought they simply disappeared if you do not pick them up? You can add mana from your current "pool" into your bank at the Armory thing during build phases, allowing you to pick more up...
But get your arse online sub, it's a much better game when you play with other people imo :)
Play online you can't use your local character online, but you can export your online to local.
yeah jump straight online fella..
join some randoms or just do a private game and play by yourself
best thing with squire is there blockades..
id recommend starting with the apprentice, get him spec'ed up then when his at top level you can respec your hero for a small fee, re spec him as a tower builder then level up a huntress and use them as a hero to do damage.
with good towers from the apprentice you can level up other heros a lot faster..
well thats what Ive done any way, with help from others from on the forum...
Im addicted to this game, add me on Steam if you want, have started one of each character so have a low one of each if you fancy duo-ing some levels. Have a level 70 apprentice that i am using to pwerlevel some of them ^_^
yeah same mate im addicted aswell..
im going to add you on steam...
edit...i will add you when every man and his dog gets off steam...
Is this game better than Sanctum? I've only loaded that one up about 3 times.
It was... until they totally ****ed up the balance. You can still get your monies worth easily but later on don't expect anything to be a real challenge. It became a grindfest where the only place to get decent gear was survival, then it became a 'pay to win' where the premium DLC was the only way to get good gear without having to spend 6 hours minimum playing.
:P I could just boost you hon, But you need to play online via trendy net, You can't use the local items online the entire point of the game is to play online!.
