duo or quad (gameing)
2 May 2007
hello,i was wondering there ant much diff in the price between these so i was wondering what would be the best to get;
Intel Core 2 Duo E6850 "LGA775 Conroe" 3.00GHz
and
Intel Core 2 Quad Pro Q6600 "Energy Efficient SLACR 95W Edition" 2.40GHz
the computer would be used for msn,aim and gameing only.
thanks a lot.
Which games? Not many are optimised for quad cores.
And the E6850 is a waste of money, there are better value dual core alternatives
No sense in you getting a Quad right now so just stick with a Duo. If you're not going to overclock and you have the cash, get the E6850. If you will be overclocking, get an E6550/E6750 or an E4500 if you want to do it on the cheap.
E2180 if you go dual and plan to overclock.
E6750 if you don't plan on overclocking.
I have just upgraded from a Pentium D930 to an E6750 and the difference is unbelievable. The fastest CPU I've ever had.
So i would recommend the E6750.
Intel Core 2 Quad Pro Q6600 "Energy Efficient SLACR 95W = £152.74
Intel Core 2 Duo E6750 "LGA775 Conroe" 2.66GHz = £119.84
Why on earth wouldn't you want two more cores for £32 :confused:
If you bought a E6750 over a Q6600 then you need your lumps felt TBH!
Indeed;)
Not that much different tbh, my Q6600 happily does 3.4GHz, I guess you might get another 300/400 Mhz out of a duo.
But remember I have another two cores under the hood :)
Mine happily does 3.8ghz 60c full load.:D
I'm not a big fan of waiting, the Q6600 is hardly "big money", enjoy it while you can and if you feel compelled to buy a new CPU then stick it on MM's
