Duplicating a DVD using iMac
1 Nov 2003
Maidstone, Kent
Hi,
I have a DVD which I created a while back using iDVD. (It has no copy-protection on it)
I now would like to duplicate it but no longer have the original files.
The DVD autoruns when inserted into my Superdrive or DVD player and performs as expected.
However I have tried to duplicate it following the instructions found here
https://www.podfeet.com/blog/tutorials-5/how-to-duplicate-a-dvd-on-macos-sierra/
with no luck.
The files are copied to the blank DVD (I can see them using Finder) but the disk doesn't auto-run on the iMac or even get recognised in my DVD player.
Can someone please help me with this?
Thanks
Hussman
Hi Chris,
Thanks for the response.
I have handbrake, but can't find a pure "Clone" option. It can convert to mp4, but I can't seem to find a way just to make a simple duplicate?
Can’t disk utility do this? Make an img of the DVD and then just write it to a new one.
The Make MKV option didn't work :(
I tried that following the instructions in the OP link.
The files copy across to the DVD but it doesn't autoplay and a stand alone DVD player doesn't recognise the disk
I've purchased DVD Copy and Rebuild Pro from the App Store. It was £10, but it does what I want.
Thanks to Chris and Feek for taking time to respond.
Hussman
Hmm, that should work.
You could try using dd from within terminal, all you’re doing is making a direct copy.
/edit - too late.
