Duplicating iTunes Library between Macs?
24 Jun 2011
Sheffield
Is there an quick and easy way to duplicate say my iMac's iTunes library to my MBP? As I started off keeping both updated accurately after a few month's one is more up to date, I'm quite bad with leaving my music in all sorts of folders, downloads, tend to remove some too etc. So in that respect its quite a pain.
Thanks for my spelling correction! Cheers for all the input, currently at work but will give it a read and work something out tommorow when I am home for a few hours.
Can't you just use the built in Home Sharing?
Assume its because he wants access to his music on both. Home sharing is fine if you only want to access it when on your home network and have your computer with your library also turned on. But not so good when on the road/out and about.
Correct, I just get messy with my music as it isn't all legit. Some may I add give me some credit! Correct uniQ.. Haven't had time to look into it yet as I've only just got back home since Friday morning. Will keep you updated.
