A mate asked me to check his girlfriends' PC this weekend after it was pulled from her fire damaged flat. The outside was black with soot but no signs of heat damage. Opening it up it looked pretty clean inside, not much soot had got in; thankfully it wan't running at the time of the fire (no-one was hurt btw).
Then I noticed the dust on the CPU fan...and the dust behind the fan
Taking the fan off revealed a solid mass of dust packed tightly into the heatsink fins.
I've seen some dusty heatsinks over the years but this beats them all! A stiff paintbrush and compressed air has breathed new life into the cooling (decided wearing a dust mask a good idea!)
It's worked fine anyway and when I see my mate i'll ask how it was running...i'd imagine the AMD 64 was running a tad warm
