Dust Filter for open top of case
16 Jan 2012
Hay guys. I have the Cooler Master storm enforcer case. After having it for a while I decided to replace the front 200mm fan which was loud with a smaller 120mm fan and moved the bigger fan to the top and only turned it on when needed as an outtake.
The front fan on the case has a dut filter but while the top fan isn't on dust can simply drop into the case and is a bit of a problem.
My question is can you buy dust filter mesh online anywhere that I could put in the top of the case.
You can see here my problem.
Thank for any advice :)
Syther101
Demciflex will make you any filter you want, you just email them with the dimensions of what you need or tell them what case you have and they may have them in stock anyway.
Overclockers stock demciflex filters, have a look on the site to see if they have any for your case.
