Dust filter mesh
11 Sep 2013
Heya,
Just a quick one - I'm building a rig in a CM Elite 430 and need to replace the plastic dust filters/meshes/thingies...
Where could I find a suitable material that I can cut to shape and just slot in?
There was a thread about it, but I couldn't find it on Search...
I considered the tights, but I'd have to build a very thin frame of something and stretch-fit them over. The brackets are literally just deep enough for a thin plastic mesh to slot into.
I also need something that can be done and swapped in 2 minutes by a very busy person, who won't have time to DIY a tights-frame filter!
