Dust Filter meshing
18 Apr 2011
Anyone know where you can get like a sheet of the stuff or what its called? Need some for my NZXT Phantom door mod.
Cheers
had thought about that, but would it restrict the airflow too much? Dont check tights out that much so not sure how big the holes in them are lol.
yeh yeh herd it all before :P
all joking aside now I think tights would work but I've never tried that... you won't know until you give it a go
haha
I might give it a go, really wanted to find some mesh like the stuff that comes on the fan dust filters or that comes with the NZXT case (both meshes are the same) so it would all match
what exactly do you need ? they sell mesh and or dust filters for many sized fans all over ? I presumed you wanted a sheet you could cut for a big area or something
Yeh that's the stuff cheers purgatory!
C64 its basically I made a new door for my phantom case and put some mod mesh in the door as I've mounted another front fan in the 5.25 drive bays. So needed some dust filter mesh so my case stays dust free.
