- 18 May 2010
Hi,
I have an Air 540 and regularly clean the dust filter however even when clean fitting the dust filter raises the temp on the probe I have installed by 8C when gaming, removing it sees the temp drop to normal levels.
This might not normally be a problem for most but the probe is next to the motherboard VRM so I can keep an eye on it, I need to keep this area as cool as possible which is fine without the filter fitted.
I have 3 x 120MM Be Quiet Shadow Wing intake fans, they are not static pressure optimised and they are awesome fans without the filter fitted, my guess is its the fans not able to pull air through the filter?
Or is it the filter being over two years old? Looks fine to me, maybe a bit saggy in its old age
Anyone else experience a similar issue and how did you get around it?
Thanks
Thanks
