- 12 Jul 2012
Ive got a 650D case, on the front it has 2 dust filters. One is the standard outer removeable corsair one and on the inside of that i have a 200mm Demciflex filter. When the PC is not in use i have a Demciflex filter for the top and for the rear exhaust, the only other holes on the case are the rear PCIe blanking plate covers which have small vent holes, i even changed them to ones that have a micro mesh.
Anyway, the other day i decided to give it a good clean out. I was suprised how much dust was on the inside, this was mainly on the fans and Phanteks air cooler. I took the cooler off and gave it a good blow out, same with the GPU as that also had dust on the cooling fins, also the case fans had quite a bit of dust on them. Any small screw holes or water cooling rubber grommets that arn't in use ive taped over them with black insulating tape to again try and stop dust getting in, its amazing how it does get in as the Demciflex filters have hospital grade micro mesh.
