Dust Magnet
2 Jan 2006
Tamworth, Staffordshire
Whats the best way of getting the dust out of your rig?
I always use the vacuum, but there is only so much i can get out.
I can't imgine how much dust my cpu cooler is storing between the fan and heatsink.
a vaccum, christ i wouldnt put one of them near my pc
my dad has an air compressor so i use that, you can buy cans of compressed air, they will do the job fine
i use a bit of coiled ducting and a plastic drink bottle, cut in half with the ducting taped between, to make a set of bellows. it has enough umph to shift the dust out of the psu.
i believe the nozzle becomes statically charged when it sucks up things, especially things with a lot of edges like dust/ hair. if your lucky enough that the nozzle is made out of metal you can just earth it every so often though.
