Dust problems
26 Nov 2008
As you're all aware, dust can be a massive issue with PC's overheating/premature deaths etc etc.
I have an Xclio A380 Plus case, it has a 360mm fan on the side, a 250mm fan on the front, and a 120mm fan on the back, now... None of them have dust filters. So... I was wondering, does anyone have any idea's on how to keep the dust from getting into my case and into my components, I was thinking about using a pair of tights, but I'm worried about static, as my hsf is less than 1mm away from the fanguard on the 360mm fan, will tights cause static? If so, are there any other methods of keeping dust out of a PC, other than keeping my room spotless every day.
I was also thinking about changing the case due to this issue, but using this case for a 2nd build, which is going to be underway very shortly, I was thinking about using the Antec 300 Gaming case, as I've heard nothing but good things about it, but then again, I do like to have my colourful lights, and side window, so I was also looking at the Antec 900-2(cable management + black backplate) and finally, I am extremely tempted to get the Antec Skeleton, just to see it in action for myself, and see what it's like cooling wise etc.
What are your views?
1/ cheap method:- make sure you have a positive air pressure in case....use a standard kitchen roll on intake fans(depending on type of fan,you might need to make up a light mesh framework for support)
2/ good but a bit noisy....a HEPA airfilter.....just make sure its a fair distance away from your machine
get a new case which comes with dust filters and silent fans like thermaltake i used to envy my mates who could afford those £100+ towers so pretty but yet so quiet well then they were now it sounds like a rocket#!!
