Dvd backups
29 Mar 2007
i was just backing up my boxset of rome when for some reason every disk is 200mb over the dvd size....... its rome season 1, and theres 5 disks, and there all 4.7 gb and the dvd disks are 4.5
dont know why the hell its like this, how can i get round this ?..... because i really dont think they had 8-9gb disks for every disk.....just because there 200mb over..... dosnt make sense....
cheers
I would use DVD Shrink 3.2, you can remove any unwanted audio and subtitle streams, you can also adjust the compression ratio in this programme so you should be able to get it on a standard DVD.
doggo
I forgot to say DVD Shrink ties in with Nero so you can set it and leave it for half an hour them come back and it's done.
doggo
surley not if AmateurJimmy is only backing up for his own purposes ( so the originals don't get scratched)
no it wont be locked lol, been here long enough to know the rules ;) youve been here long aswell shadow, you should allready know its perfectlly legit
cheers doggo
cheers doggo
Your welcome, I don't think this will break any rules either as they are not a competitor, you can find DVD Shrink and lots of other useful tools on doom9.org, they have lots of useful DVD related sutff.
doggo
