DVD Creator
18 Oct 2002
I have a number of avi files that i want to put onto one dvd disk and have a simple menu if possible. is there any software that you can recommend to do this (free if possible :) )
i have a convertor to convert them to VOBS but dont know the best way to put them onto a disk.
the last time i did this the movie jumped at every chapter and cut a few mins off the end of each clip, tho i cant remember the name of the software.
any help appreciated :)
Clerkin said:
can you. i didnt realise. i'll give that a bash
would prefer to add menu tho if you have any other suggestions
Try svcd2dvd for your Avi to Dvd conversion which you can add basic menu's then Dvd shrink. I prefer TMPGEnc Dvd Author myself but that is not freeware.
try this program ,had no trouble
Hi there this is true ,its not free ,but i use a program called Covertxtodvd its very good ,will put menus on abd a background you choose,it converts avi to dvd ,i have used it ,and they play on my dvd player no trouble :)
holy thread ressurection :eek:
cheers for advice though
been using nero 7 recently with the recode thing. works really well.
