I just bought a new monitor, plugged it all in, fired up windows, inserted the install cd for the monitor. I went into my computer and my drive wasn't showing up. A drive shows up in there (G: DVD Drive), but this never did anything, I always used D: CD Drive, and this isn't here.
I went into device manager, and the only thing under the DVD/CD-ROM drives was something called:
OFAREV M38P2J0DM SCSI Cdrom device.
I've never noticed this before, not that I would have paid much attention, but it looks a bit odd.
So I restarted the computer, look in the BIOS, and the Primary IDE Device is set to:
@L%DT-ST DVDRAE GSA-4167B
Again this looks different but I couldn't tell you what it used to be.
Booted back into windows and this time there was another item in the device manager with a yellow ! next to it - @L%DT-ST DVDRAE GSA-4167B
In the device status section it said This device cannot start (code 10). I uninstalled it and it re-installed itself again and the yellow ! went away. So I opened the drive and put the cd in, as soon is started reading it though I got a BSOD with Machine Check Exception on it.
SO I shutdown again, checked all the cables inside because I have been playing with fans inside the case so may have knocked it out but all looks fine. Booted again and there's no drive showing in my computer or device manager
There's clearly power as the drive opens and spins. Just not recognised in windows (XP), also checked in linux and it looks to be screwed in there too, although I can't say for definite as I've never even used it before in linux.
Any ideas what's going on?
Thanks for any help.
eek
