DVD drive not recognised on laptop.
30 Jan 2004
I've having a bit of a problem with the DVD-RW in a friends computer. Basically I have just been cleaning up the computer to get rid of all the rubbish but in the mean time I seem to have nakered up the driver for the DVD burner, so much so that the computer doesn't even recognise that it's there :/
Now, as far as I know it shouldn't require a seperate driver as windows should have the drivers for optical drives as part of the installation? However, I can't even put the windows drive in to fix the installation as the DVD drive doesn't worrk!
Can anyone help? The laptop is an Evesham (unsure of the model), and the DVD drive is a Sony DVD RW DW-D56A according to the device manager.
Cheers.
Cheers for the idea, but the drive doesn't appear in the list for me to assign it a letter, only the C drive is there.
When I try to look at the drive in the device manager the drive is listed there but it has a yellow circle over it with an exclamation mark in it.
Yep, just tried that. Uninstalled the drive then rebooted, windows picked up the drive but it still appears with an exclamation mark over it in device manager :/
I've done a bit of looking around and it seems to be a lot of other people that have had the same problem, but no seems to have a definite fix. Some people mention editing the registry key.
Instead of removing the drive itself remove the ide controller it is atatched to and then try a re-boot, this has worked for me in the past.
Mmm, I'm not really sure which one it's attached too, and don't really just want to start uninstalling random stuff!
Is it the windows driver that's corrupt?
Yeah, just delete the lower filter key- its probably been left behind by a badly-behaved application uninstaller.
This fix has worked for people in the past- Im pretty sure I had a thread telling someone to do it a while ago but cant for the life of me find it :)
