Hi
Long time since I was here but I remembered where the best advice comes from.
Just started to use Handbrake to encode some DVD's into an iPad 2 format but was horrified to see my old system was going to take around 18 hours to encode a 30 minute episode.
I didn't realise my old PC was so out of spec:
DFI nFoce 4 motherboard,
AMD Athlon 3200+ 2 GHz cpu,
1 GB RAM,
Radeon X800 graphics card
Anyway, I don't play games on this machine anymore just need it to do encoding and a few other cpu/memory intensive tasks.
I don't want to spend more than £300 on components if possible, can you please spec me a machine within this budget?
I presume I can get away with CPU, motherboard, RAM?
I'm using Windows XP at the moment which limits the RAM I suppose?
Many thanks
Tricky
1 GB RAM,
Many thanks
Tricky
