Hi,
I have a Phantek Enthoo Case which is awsome, but it has a slightly aluminum looking finish on the front and when I put a black DVD drive into it you can notice it.
Is there anywhere I can buy a faceplate or somethign to help match the DVD drive to the case?
Thanks
Thanks
Just make sure if you do decide to try, use good strong tape.
