- 15 Sep 2006
- Liverpool
OK I need some help with this.
I have lost one of the disks from my Lost Season 1 box set.
So I have downloaded the 4 episodes that were on that disk and am trying to burn them to a DVD+R. I have tried converting them to DVD format using WinAVI Video Converter. I opened one of them in Nero Express and it was about 1GB in size. Should be alright, 4 episodes @ 1GB each should easily fit on a DVD+R (4.7GB).
So I converted the rest of them and tried to add the files to Nero Express to burn. Now this might seem very silly, but I can't add all the files to burn because all of the episodes in DVD format have the same filename (e.g. VTS_0_1). So when I add a second episode it asks to overwirte the files; I choose no and it doesn't add them at all.
I tried the same thing in the bigger Nero Burning ROM program but couldn't figure that out either.
Any idea on another way I could do this? I'm pretty sure I can't rename the files, someone told me they won't work properly if I rename them.
Sorry if I haven't explained this very well either.
I just tried Nero Vision and all 4 don't fit onthe 1 DVD+R.
