13 Mar 2006 at 17:06 #1 LabR@t LabR@t Soldato Joined 30 Nov 2005 Posts 13,916 when watching widescreen DVD on my widescreen monitor I still have Black bars top+bottom how do i get rid of them?
13 Mar 2006 at 17:38 #2 Hussman Hussman Associate Joined 1 Nov 2003 Posts 1,270 Location Maidstone, Kent You need to use the pan & scan options in your DVD play-back software. You will probably loose a little from the sides of the picture, but at least you will get rid of most of the letterbox effect.
13 Mar 2006 at 17:41 #3 LabR@t LabR@t Soldato OP Joined 30 Nov 2005 Posts 13,916 Never understood why if using a widescreen screen you have to have letter box really , but cheers for the info
13 Mar 2006 at 20:15 #4 MadMatty MadMatty Associate Joined 14 Jan 2005 Posts 1,571 Location Lincoln, UK you still get the bars at top and bottom on the widescreen monitors because the source material is in a 16:9 ratio and the monitor is natively 16:10. You can use the smartstretch in PowerDVD to try and make it fill the screen without making it look to ..streteched.
