dvd rom not working??
8 Dec 2007
wales
hi guys for some reason my dvd writer has stoped working.
device manager says Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
please help
did a quick google for 'code 19' and found this (it worked on xp home, dont know much about vista 64 so I would suggest investigating a bit more first):
1. Click Start.
2. Click Run.
3. In the "Open" field type REGEDIT.
4. Click OK.
5. Click "File" in the menu bar.
6. Click "Export" from the drop down menu this will open a new box.
7. Click the down arrow beside "Save In" and select "Local Disk (C".
8. In the File Name field type BACKUP.REG.
9. Verify that under the “Export Range”, that the radio button is beside "All".
10. Click Save.
11. Click the plus sign (+) beside HKEY_LOCAL_MACHINE.
12. Click the plus sign (+) beside System.
13. Click the plus sign (+) beside CurrentControlSet.
14. Click the plus sign (+) beside Control.
15. Click the plus sign (+) beside Class.
16. In the left hand window pane click on {4D36E965-E325-11CE-BFC1-08002BE10318} to select that key.
17. In the right hand window pane select the UpperFilters registry key and press the delete key on the keyboard.
18. Confirm with an OK.
19. In the right hand window pane select the LowerFilters registry key and press the delete key on the keyboard.
20. Confirm with an OK.
21. Click the "X" in the upper right hand corner of the Registry Editor window to close it.
reboot and hopfuly the drive will be located and drivers installed
