dvd to nas drive
20 Oct 2012
west sussex
Hi all i have recentlly purchased a rasberry pi to run kodi from a nas drive.
Can someone reccoemend a good piece of software (free or paid) to copy from a disk to the nas drive.
thanks
Not really.
as above, makemkv to get the movie from the DVD as is. Will be between 4-6gb on average.
Run it through Handbrake on the high profile preset, size will come down to between 1-1.5gb.
If you are a perfectionist, you will spot small quality loss, but you will have to look hard.
It will also depend on the TV used to watch it.
To do Blu-rays (might be stating the obvious) you will need to get a blu-ray player, I did all mine at the native size and this can vary between 20 - 40gb plus.
ok so using that software removes the need to use the disk as that was a security feature of a bluray you could rip/burn or whatever onto a hdd but needed the disk?
