DVI 29pin
25 Sep 2010
Ok so i got my 5850 video card today, and when i plug my normal 19pin DVI from screen to the card, nothing comes up, and it just says please insert vga cable, i then tried using the adapter that came with the card 29pin DVI to vga (analog) and it works perfect, but the downside is its still analog :s
Whats the deal with the 29pin stick ? and is there anyway to use it with my monitor that only has the 19pin input ?
