Dvi / analogue
11 Jan 2005
Birmingham
Looking for a 19inch widescreen tft, and, does this make any difference?
THe hans ocuk screen seems to fit into my price range really nicely, and has dvi. Does dvi give any advantages, better quality or not really for a cheapish monitor?
From my own personal experience, the difference between analogue and DVI isnt so significant that I would HAVE to buy a DVI monitor over an analogue one, but it does look slightly nicer. I found this was most noticable on the Windows interface rather than on games itself as it looked a lot sharper. Just my opinion anyway.
I also read that analogue on some TFT's are comparable to DVI on others, so I guess the picture quality is more down to the TFT model itself rather than wether its Analogue/DVI.
Im not in the market for a TFT at the moment, but I have noticed that the price devide between analogue and DVI TFT's isnt that great anymore, so if you are willing to stretch your budget by £30 or so, then go for DVI I say.
Well i have just got an acer 1916w and its d-sub only, tbh i think the picture is fab. I was concerened about this prior to purchase, so i pondered it for a while until i saw some reviews and just went for it! :D
from the sticky as well ;)
Q. Does DVI make a difference?
A. This depends very much on the panel in question. Some users of some panels say that switching between VGA and DVI makes NO difference on their screens. Notably users of the Samsung range (171T, 181T, 172X) have said it makes little or no difference, and has even been tested by users with 2 side by side. Other users of different panels swear it DOES make a difference. For example, I have personally seen the LG1710B in action in both modes, and the DVI was noticeably better quality and much sharper than the VGA. However the DVI connection on the LG I would rate as comparable to the VGA on some TFT’s without DVI at all, including the AOC LM720a. It seems logical that perhaps some manufacturers who build their screens without DVI spend more time perfecting the VGA connection as that is all they offer. Whereas companies who supply both connections sensibly would expect their users to use the DVI connection, as it is there, and so sacrifice quality of the VGA as the DVI can show off the full potential of their panel. Therefore screens without DVI tend to have a better VGA than those with DVI and in some cases a good VGA connection can be comparable in quality to a DVI connection.
Quality of the VGA connection is also related to the GFX card used. Most modern GFX cards have a good VGA output and this is important in image quality of the TFT. NVidia cards have been said to have a slightly better VGA output than the ATI cards, but as said, most new cards will give u a good quality output. Good output combined with a good VGA input on the screen will give u a good quality picture.
One other thing to note is that when using DVI connection, most TFT's lose the option of some of the on screen settings like contrast and brightness, so if u use DVI and u cant change them, some people have found the screens too bright. Software fixes are available for this though (inc Powerstrip etc)
RILOT: "I have non DVI TFT’s and the picture quality is exactly the same as my friends Samsung TFT that does have DVI. We tested them both together. Oddly though, when using the Samsung with VGA input the image quality was significantly worse......If you have a card with a decent 2d quality output it shouldn't make any difference whatsoever."
