DVI Cable question
20 Feb 2009
Stafford, Staffordshire
just wondered if anyone can answer a few questions I have about cables:
1) does the brand make any difference on a ATI 5870 (2 monitors @ 1920*1080 each)
2) what is the max length you can use before you start losing quality?
1) no - brand doesn't matter. Just get a single link DVI-D cable that looks like it is reasonably well made.
2) The DVI spec requires a DVI cable to work fine at 5m lenths. In practice I wouldn't use a basic cable any longer than 10m.
