DVI connection query
23 Jun 2006
my friend needs advice
anyone know if you can use a dvi type connection graphics card with a normal monitor which has no dvi? Can you get an adaptor?
as said, you'll probably get one with your card.
have a feeling that image is the other way though :confused:
That image is right, the pins are always on the monitor end, so they plug into the vga end of the adaptor and dvi pins go into the card.
