DVi connectors
8 Feb 2006
Stafford
:( correct me if i am wrong there are two types of socket
both similar
but the flat connector (looks a little like the end of a flat screwdriver end, has 2 types 1 surrounded by 4 pins and the other no pins,
ive recieved an adapter off ocuk, to convert my xerox monitor dvi only to hdmi and of course the adapterhas no where 4 the 4 pins and the flat pin is smaller and on my monitor it has the pins and the flat pin is also too big for the adapter anyway
advice please
Near the bottom of this page are diagrams of the different DVI connectors
http://www.datapro.net/techinfo/dvi_info.html
Ones with 4 pins around the flat pin are Analog or Digital/Analog (DVI-A , DVI-Single Link , DVI Dual link)
All of my LCD screens have the DVI-D Dual link connector (so no pins around the flat pin) (as it happens I'm apparently only using DVI-D single link cables)
If i'm understanding it correctly you have a DVI-D to HDMI adaptor and that is incompatable with your DVI-A monitor.
Havent seen anything with the 4pins around the flat pin for quite a while.
