Got my DGM 27. It came with a DVI-D cable but a bit short for my Humanscale M2 cable management. I ordered a longer DVI-D (24+1 pins) from ebay. It doesn't not work! I thought any double link DVI should work. Or I am wrong?
I am sure my card is dual link cause the original cable works. One thing I just notice is that the cable I bought looks a bit different from the one OCUK sells. If you check the pic in OCUK link, http://www.overclockers.co.uk/showproduct.php?prodid=CB-067-OK&groupid=1929&catid=1754&subcat=, near the connectors there are Ferrite Cores. The ebay one does not have them. I guess that would be the reason?
So that is not the reason the cable won't work. Hmm I guess that is just a crappy cable then. Is there any advantages with displayport over DVI? I might consider getting one.
