DVI-D Not working DVI-I works fine?
21 Nov 2010
Hi All
I have DVI-D and DVI-I Dual Link options at the back of my card though the D does not display anything on my Hazro 27B monitor only the I.
Why is this? Hazro 27B should be DVI-D right?
Thank You
DX
Hi there,
Is the DVI-D connection dual link or only single link? If it is only single link then it won't have enough bandwidth to send the full 2560x1440@60Hz signal to your monitor - so it wouldn't work.
If your DVI-I dual link connection is unused (or underused) then I would suggest switching over to that, since the dual link will happily provide all the bandwidth the monitor requires. Don't worry about the difference between DVI-I and DVI-D, DVI-I just means it includes all the connections for an analogue and digital video connection. If you use a DVI-I connection with a DVI-D cable and monitor then it will connect up fine and look just as good as a native DVI-D connection.
Hi
I think its a Dual Link cable with the pins going full left to right no gaps then one pin to the side both ends.
So I'm not missing out on anything better display etc there is no need to get another cable DVI-I and D are the same?
Aye, but it may have all the pins, but still only be single link. For example this HD 6970 has a single link DVI-D port (the upper DVI port in the end-on photo) which looks like it has all the pins, but is in fact only single link (so it couldn't drive a 2560x1440 monitor like yours), when in contrast the identical-looking lower DVI-I port is full dual link and could drive a monitor like yours. May I ask what particular graphics card make and model you are using?
You are definately not missing out on anything when using a DVI-I port instead of a DVI-D port. When used with a DVI-D cable and monitor, the DVI-I port works just like a DVI-D one and the DVI-A (analogue) parts which differentiate it from a normal DVI-D port are effectively bypassed.
You won't need a special DVI-I cable to get the most out of a DVI-I port - a DVI-D cable works just fine. Though obviously you will need a dual-link type DVI cable to support your resolution.
Ok the card is a 6950 2GB HIS Fan Dirt3 Edition I got it for £189 so it is a bit cheaper then most 6950s.
The top DVI Port on the card is Single Link now you have pointed it out.
