DVI D - VGA help
16 Jun 2009
Hi, not sure if this should be in monitors or graphics cards
I have a GTX 760 that has a DVI-D output, I have a monitor that only has a VGA output.
Will buying a DVI-D to VGA adapter work?
Thanks in advance!
Please remove the competitor discussion.
A GTX 760 should have a DVI-I connector.
If you're not already using this you can use one of the DVI-I to VGA adapters which are usually chucked in the box with graphics cards.
