DVI/HDMI Outputs
25 Oct 2013
Kent
Hi
I have a R9 290x, I am trying to clone my monitor to my capture card.
I want to run 120hz to my monitor (DVI) and 60hz to my capture card (Via HDMI) but when I try and clone it downs them both to 60hz.
I think the problem is CCC thinks the capture card is a HDTV. If I replace the HDMI and run it from the 2nd DVI port on my 290x would this still pick it up as a HDTV or will CCC pick it up as a monitor?
Im trying to work out if it is the HDMI that is causing the problem. If not is it a bug with CCC.
Thanks in advance
