My motherboard has a DVI-I connector at the back, is this going to be compatible with DVI-D monitors?
Edit: never mind looks like I may have the answer
The long flat pin on a DVI-I connector is wider than the same pin on a DVI-D connector, so it is not possible to connect a male DVI-I to a female DVI-D by removing the 4 analog pins. It is possible, however, to connect a male DVI-D cable to a female DVI-I connector.
