6 Dec 2009 at 18:05 #1 your_mum your_mum Associate Joined 25 Oct 2009 Posts 58 If I have a moniter with DVI-I, and a graphics card with DVI-D, will this work?
6 Dec 2009 at 18:21 #2 evoyear evoyear Associate Joined 24 Oct 2009 Posts 291 Location Edinburgh I think so, the two plugs look similar, hope someone more professional will help u later
6 Dec 2009 at 18:25 #3 ajstan ajstan Associate Joined 3 Jan 2009 Posts 2,056 Location London Yep, DVI-I has an additional pin for analogue, but you won't be needing this if your GPU has DVI-D (Digital). So yes it should work fine
6 Dec 2009 at 18:28 #4 your_mum your_mum Associate OP Joined 25 Oct 2009 Posts 58 Thankyou so much. Finally, how reliable are adapters from DVI to HDMI? - if they exist
6 Dec 2009 at 18:35 #5 your_mum your_mum Associate OP Joined 25 Oct 2009 Posts 58 WIll I need HDMI to fully appreciate the graphics?
6 Dec 2009 at 19:04 #6 95thrifles 95thrifles Permabanned Joined 15 Nov 2008 Posts 6,968 No, DVI and HDMI are the same quality, HDMI just also carries audio, assuming the source outputs audio
