Out of interest for 2560x1440 and 1920x1080 which is the generally the preferred connection, dual link DVI or display port?
I've noticed increasingly new cards seem to have dropped having multiple DVI connections in favour of a mix of 1xDVI, 1xDP and 1xHDMI, some with 2 x DP.
I currently use two screens from my 5970 via dual DVI but it's looking like if I go for a 7970 I need to switch to DP. I have a feeling that one screen on DVI and one on DP would be a recipe for problems and tearing.
Which leads me to a cable question. Most GPUs (albeit from a really quick scan of stock) seem to have mini DP connections and most screens (that have DP) have full sized DP ports. Are people using for mini - full DP cables ,of which, again at a quick scan there doesn't seem to many (any?) about from places like OCUK at the moment. Or are people just using standard cables with mini to full size DP adapters? Has anyone any experience with the DP to DVI adapters (my second screen doesn't have DP in so do I end up going mini DP on the GPU to DVI through an adapter on the back of the screen (the second screen has DP so would be a direct mini to full DP connection I guess).
Or am i just better off looking for a decent 7970 with two dual link DVI connections?
Thoughts?
Thoughts?
