DVI PC Monitor and speakers. Need help.
12 Dec 2005
I connect my Xbox 360 to my PC Monitor. My PC Monitor has speakers which aren't very good. It also has a sound jack on the back of it.
I tried connecting my speakers into the jack of the monitor but nothing happened. Is it possible to get them working this way?
Thanks
What are the inputs for your speakers?
A 3.5mm male only?
If so you could buy one of these: http://www.amazon.co.uk/XBOX-HDMI-C...58RW/ref=sr_1_4?ie=UTF8&qid=1341762538&sr=8-4
They work along with the HDMI cable you are already using.
Then buy a phono Male to 3.5mm female cable:
http://www.amazon.co.uk/3-5mm-Stere...2?s=electronics&ie=UTF8&qid=1341762588&sr=1-2
Right now I use one of these
It goes into the back of my Xbox 360, and then I use a 3.5MM to RCA Jack cable which then goes into the line in port of my sound card.
However, I get a horrible amount of static this way.
I was just trying to figure out another way of doing it so I could get less static...
I'm not fully sure I understand the way you're saying... Please could you break it down for me?
Thanks
I think I've figured it out, if I do it the way you suggested, I won't even need to plug anything into my sound card?
Thanks
My local high street game retailer used to sell it - it's a proper MS accessory. The RRP used to be silly until the public realised that HDMI cables were not made out of unicorn hair. I think they're around a tenner now.
I have this already
I'm having a hard time locating this cable locally:
