Ive just bought a macbook but found ithat i wont be able to connect it to my 30'' LCD ,as the Macbook dont support dual link.
Ive bought with the Macbook the dvi adapter......Is there any box of tricks out there which could convert a single link dvi to a dual link dvi?
Or would it be possible to go from a DVI to hdmi with a converter cable which i have then back to hmi with a HDMI to dvi converter
Do you think that would work?....or is not ust not possible?
Thanks
Thanks
