Caporegime
- 21 Jun 2006
would it be worth say £10 to buy a DVI to HDMI cable to run my 32inch HD LCD TV which is a Sammy currently running using a VGA cable and a vga to dvi converter to connect to my x1900xt? will the picture quality improve? will the signal quality improve? will it change anything at all? or should i just keep my current setup? if it improves image quality in any way surely it would be worth it since im using such a big widescreen lcd
