dvi to vga adaptors?
15 Nov 2002
bed or the pub
Hey fellas i'm about to change my gfx card but the new one has no VGA port, being a HD4870.. my monitor is for the moment an old CRT but i'd prefer to keep it for now till i've got a bit more cash to get a really nice monitor.
I've seen adaptors that look like you can plug a vga monitor into a dvi graphics card, but, do they work? are they any good? :confused:
Yep, I've done that plenty of times. You're more than likely to receive one with the card so just plug it in and use like normal.
its a pretty standard thing, you get one or two with every card (well, all the cards ive ever bought) and they work perfectly fine.
