DVI to VGA confusion - Please help
30 Jun 2005
Hello,
I have 2 PCs 1 with a DVI video out and the other with a VGA out. I recently purchased a ATEN KVM switch Link. I found that the KVM switch has 2 DVI male connectors, so i connected 1 to the first PC (with DVI connector) which works fine, but the other i tried using a DVI to VGA connector as the 2nd PC only had a VGA output. This does not work, the connector i purchased was "StarTech.com DVI-I Female to VGA Male Adapter".
Any idea what is wrong? Thanks
Looking at the pinout for the DVI on the KVM switch it matches DVI-D, so does this mean i cannot connect a VGA output to this (which i assume is analogue)?
unfortunately :( you'll need to get an electronic converter (probably powered) that will convert VGA (analogue) to DVI/HDMI (digital).
The other choice is to buy a VERY cheap PCI/AGP/PCI-e graphics card to fit in your PC that has the VGA on it. that will have a DVI-I connector which I believe should work (DVI-I carries both analogue and digital)
That's a shame, good job i have an analogue in on my monitor, bit of a pain having to switch both the KVM and the monitor but not worth the outlay to get the KVM to work.
The 2nd PC is a brand new laptop (work) very surprised it does not have HDMI or a DVI out.
Thanks for the help though
