Deleted member 88651
Hi guys, I have a palit gts 250 which on it specs states that it has Two dual-link DVI outputs. However on the interface of the card I can only see a dvi and a vga socket. I currently have a dvi monitor connected to the dvi port and intend on buying another dvi monitor which of course will be connected to the vga socket via some dvi-vga adapter. Will this method downgrade the resolution/quality of my new monitor (which should natively run @ 1920 x 1080). Any further specs about the card can be found here http://www.overclockers.co.uk/showproduct.php?prodid=GX-121-OK.
Thank you for your help.
