DVI With NEC20WGX2
i think he means does it come with a dvi cable or not? I seem to remember it does, not 100% though.
edit: actually, reread the post and considering he got it a few days ago, i'm guessing he knows whether it came with a cable or not!
Kreeeee said:
DVI is noticeably cleaner and crisp on my 20WGX2 compared to VGA.
Strongly agree with ya on that one, I only use my vga to gain access to the BIOS otherwise its DVi all the way!!
Hi all,
It doesn't come with a DVI cable no :p
Ok, I read that with some screens DVI makes to visible difference at all. But for £8 odd on OCuk I think I will pick one up.
Not paying the £50 that certain high street electrical stores are charging for them though!!
Jamrasta said:
Hi all,
Stange, my monitor from OCuk did?
Jamrasta said:
Hi all,
Officially, yes it does. They must have missed it from your package but that doesn;t mean you can say no it doesn't come with a DVI cable, only that yours didn't.
Jamrasta said:
Strange. All i got was a power cable, a VGA cable and a usb cable.
I've been swindled :eek:
Having said that I think I didn't have a USB cable? Which I think is used so you can use the USB ports at the left handside of the monitor!!
Picked one up from work so wasn't a major issue for me!
I'd contact OCuk if thats where you purchased it from and see what they can do for you, or pick one up from an auction site cheap? ;)
I had in mine:
1 x DVI 1.8m cable
1 x VGA 1.8m Cable
1 x 1.8m USB A-B cable
1 x 3m Kettle Power Cable
You guys been ripped off :)
