OcUK Staff
- 26 Nov 2014
- Stoke
We've just received a container of DXRacer chairs, including the new King and Drifting series, along with an expanded Formula range. Here are some highlights!
DXRacer OH/KF06/NB King Series Gaming Chair - Black/Blue @ £279.95 inc VAT
One chair to rule them all - The KING-Series is a newly designed seat with 4D sliding and adjustable armrests, which are padded for extra comfort. The KING-Series is DXRacer’s widest model of chair, and offers a sleek ergonomic design for maximum comfort. This chair is designed to stay comfortable for long sessions, including those that are 8 hours or longer. This chair is fit for a King!
All the accessories have passed 72 strict quality tests and we provide two years warranty on them. Our new base has been designed by teams of foreign professionals to last indefinitely. The KING-Series offers one base and one type of texture. The base is made of aluminum and the texture is PU material. This model has a maximum load of 181 kg (400lbs).
Features
- Quality and Security: All the accessories have passed 72 strict quality tests.
- Imported Hydraulic unit: The hydraulic unit is imported from Germany and passes stringent SGS and exceeds International standards.
- Adjustable system: The height and angle of the chair can be adjusted to any degree.
- Full-size frame: The DXRACER chair has a full size frame inside. We adhere to strict quality controls to bring you the ultimate in comfort.
- Footrest-shaped base: Our new base has been designed by a team of specialized professionals to last indefinitely.
- Functions: Raise and Lower, Specially designed handle - Toggle gently and lift quickly
- Resilient armrest surface: DXRACER imports superb quality polyurethane. High quality surface enables you to rest your arms - Soft, pleasant to touch and comfortable
- Large angle adjuster: A typical feature of the chair, All steel framework - 170 degree limitless angle adjuster
- Multi-directional ergonomic design: 10 years of ergonomics research, Optimum structure curve and perfect ratio - Supports your spine and offers superb comfort
- Universal casters: Covered in advanced racing quality PU, Combined with heavy ABS - Firm, durable, safe and quiet
- Newly designed base: A world first footrest shaped base, Stamped with a racing tire pattern: Help to rest your feet and sit comfortably
- Rocking function, set the seat at any desired position "Rocking" is possible in any position.
Specification
- Manufacturers article number:OH/KF06/NB
- Colour: Black & Blue
- Article no.:7346
- Guarantee: 2 years
- Pillow & cushion: Included
- Armrests: 4D Adjustable
- Base: Aluminium
- Gas lifts: Black steel
- Material: Synthetic Leather
- Weight limit: 180kg
Only £279.95 inc VAT.
ORDER NOW
DXRacer OH/KF06/NW King Series Gaming Chair - Black/White @ £279.95 inc VAT
Features
Specification
- Manufacturers article number:OH/KF06/NW
- Colour: Black & White
- Article no.:7495
- Base: Aluminium
ORDER NOW
DXRacer OH/DF61/NWR Drifting Series Gaming Chair - Black/White/Red @ £224.99 inc VAT
Steer your way toward our DRIFTING-Series! With added high-density cold cure foam padding on both the backrest and the seat, these chairs offer exceptional comfort. Extra padding makes the DRIFTING-Series ideal for extended use, maintaining superb comfort for sessions lasting 8 or more hours. DRIFTING-Series also offer a much deeper seat than the RACING-Series.
With a tubular steel frame and a metal star base, as well as comfortable and one dimensional adjustable armrests, the DRIFTING-Series offers superb stability. With an integrated headrest, adjustable lumbar support cushion, and a tilt-mechanism angling all back the way down to 170 degrees, you're sure to be comfortable. The DRIFTING-Series offer different bases and covers.
All the accessories have passed 72 strict quality tests and we provide two years warranty on them. Our new base has been designed by teams of foreign professionals to last indefinitely. The maximum load for this chair is 120 kg (265lbs).
Features
Specification
- Manufacturers article number: OH/DF61/NWR
- Colour: Black, White & Red
- Article no: 6394
- Armrests: Adjustable
- Base: Aluminium
- Material: PU Leather
- Weight limit: 120kg
Only £224.99 inc VAT.
ORDER NOW
DXRacer OH/DF61/NWB Drifting Series Gaming Chair - Black/White/Blue @ £224.99 inc VAT
Features
Specification
- Manufacturers article number: OH/DF61/NWB
- Colour: Black, White & Blue
- Article no: 6395
- Base: Aluminium
ORDER NOW
DXRacer OH/FD01/GN FORMULA Series Gaming Chair - Black/Grey @ £199.99 inc VAT
The FORMULA-Series is DXRacer's answer to those seeking affordable luxury. These chairs are well-known to eSports players and their fans. The FORMULA-Series’ high-density cold cure foam filling makes these chairs comfortable for extended use, especially for durations of 8 hours and longer. With a tubular steel frame, as well as comfortable and adjustable armrests, the FORMULA-Series offers superb stability.
With an integrated headrest, adjustable lumbar support cushion, and a tilt-mechanism angling all back the way down to 170 degrees, you're sure to be comfortable. All the accessories have passed 72 strict quality tests and we provide two years warranty on them. Our new base has been designed by teams of foreign professionals to last indefinitely. The maximum load for this chair is 120 kg (265lbs).
Features
Specification
- Manufacturers article number:OH/FD01/GN
- Colour: Black & Grey
- Article no.:7835
- Base: Nylon
- Material: Fabric
Only £199.99 inc VAT.
ORDER NOW
DXRacer Formula Series Gaming Chair - OH/FE08/NE - PU Black Leather - Green Flashes @ £199.99 inc VAT
High and straight back. The majority of office chairs currently available have low backs which make it impossible for you to rest your neck. The DXRacer computer chair has successfully overcome this problem. It helps to maintain a 90 degree angle at the hips when seated, one of the three right angles (knees, hips and elbows) recommended in medical circles. The chair offers a 180 degree angle adjuster. The back of the DXRacer office chair can be adjusted to any angle as needed. It can even be lowered to a horizontal position for napping, making it especially suitable for overtime workers at night.
Adjustable armrests. The armrests can be adjusted to the desired height permitting a right angle at the elbow joint to support long term use of the computer mouse. This protects the user from slanting shoulder and kyphosis resulting from fatigue of shoulders and wrists with prolonged use.
Star shaped aluminum chair base with footrest pads. Designed by DXRacer's engineers, this patented design is stronger than steel. The DXRacer office chair can be moved around safely and is completely stable. It embodies strength with modern styling, offering the utmost in convenience.
Adjustable height. The height of the DXRacer Office Chair can be adjusted in accordance with the height of your office or computer desk. Its extreme flexibility and adaptability will make your office life more colourful.
Specifications:-
- High and straight back
- 170-degree angle adjuster
- 8 position height adjustable armrests with softpad cover
- Black aluminum star base with footrest pads
- Adjustable height gas-spring
- Integrated headrest
- Adjustable backrest down to a reclining position
- Tilt mechanism with lock
- Adjustable seat flexibility
- Headrest pillow and lumbar cushion are included in the package
- Supports load up to 120 kg
ORDER NOW
CHECK OUT THE FULL RANGE HERE
Features
Specification
- Article no.:7346
- Base: Aluminium
ORDER NOW
Features
Specification
- Article no.:7495
- Base: Aluminium
ORDER NOW
Features
Specification
- Article no: 6394
- Base: Aluminium
ORDER NOW
Features
Specification
- Article no: 6395
- Base: Aluminium
ORDER NOW
Features
Specification
- Article no.:7835
- Base: Nylon
- Material: Fabric
ORDER NOW
Specifications:-
ORDER NOW
