DXRacer lockable caster wheels
6 Jun 2009
No Mans Land
Hi there,
I bought a DXRacer Max series chair last year which has been great. Since getting into racing sims this year the one thing I wish I could do is lock the wheels when I'm playing so the chair does not keep moving back etc.
Does anyone know of some compatible 3rd party lockable caster wheels you can get?
Cheers
As an alternative, I found those castor cups you can get did the trick on my carpet. You can get them for 50p each in Wilkinsons. Depends what your flooring is, but worth a try.
I had a Vertagear chair for a few days and while I didn't get on with it the castors were amazing.. weird but yeah and I'd love to buy some for the chair I ended up keeping which are using plain unbranded castors I bought from the rainforest.
An original castor broke but under warranty I got a new 1 sent out, ages later another 1 broke out of warranty and it's cheaper to buy a whole set rather than a single.
I now always use these instead of castors. Chair will still move/slide when need be but needs a bit more effort and doesnt ruin the carpet like castors do.
