- 21 Nov 2011
Hi guys,
Trying to do some recording at the moment, using Dxtory and the Lagarith Lossless Video codec. I'm getting a horrible colour corruption when playing the videos back, only way I can stop it is to check the option "Prevent Upsampling when Decoding" and using the RGB setting under the codec.
Some googling has unearthed that this setting stops the codec from doing any "colourspace conversions", which I'm therefore assuming is what is causing the corruption.
Any ideas how to fix (as RGB uses more MB/sec) or can anyone recommend another codec to use?
Cheers
Cheers
