Dying Light
12 Mar 2006
N.E England
Hi All,
Stupid question but I'm a bit out of touch can anyone advise me how Dying Light would run on a GTX480 X 2 in SLI with an old i5 and 4GB of system Ram?
or am I better getting it on the PS4 :eek:
Many Thanks...
Hi All,
Many Thanks...
My vote would be PS4. Your get a good expereince on the PS4. But your pc alas needs modernising.
480's lack the vram and grunt. And your 4gb of system ram is also not enough.
It wouldnt take much to transform the pc. An extra 4Gb of system ram and a new GPU.
Better getting it on the PS4 ;)
CPU: Intel Core i5-2500 @3.3 GHz / AMD FX-8320 @3.5 GHz
CPU Speed: Info
RAM: 4 GB
OS: Windows 7 64-bit / Windows 8 64-bit / Windows 8.1 64-bit
Video Card: NVIDIA GeForce GTX 560 / AMD Radeon HD 6870 (1GB VRAM)
Sound Card: Yes
Free Disk Space: 40 GB
Forgot the 480s were only 1.5GB :p
So what? the 560 and 6870 are 1gb so they're certainly better than that.
OP - do what I did and try it before you buy it. Can't say that about a console !
For me it ran fine for a while, then fell to bits. Mind you it was Nvidia's fault as they broke the SLI profile.
If you get stuck holler, it's easy to change the profile for SLI.
Wash your mouth out with soap !!!
Uses nearly 2gb of ram on my 670 on medium textures. Might be OK if you set textures to low.
