Dymo label manager 160
5 Aug 2013
Shropshire
As title - Has anyone got one of these and if so is it worth having - I need to label up storage boxes in garage and wife can also put labels on her plant tags.
Also do these labels stick like poo to a blanket.
We use Dymo's at work, previously the RHINO range and now the XTL range.
The stickers are awesome they definitely stick.
I have one at work and use it a lot. They are good models however the keypad is squishy as hell vs the old Dymo Rhino I used to use. It would be nice if there was a easy way of deleting characters because you have to repeatedly smash the backspace button to do so. I have no major issues with that unit itself. It uses 6xAAA’s and these typically do last a while.
Label adhesive (be sure to apply to a dirt free surface) is excellent with Dymo stuff however I’m using third party labels as they’re cheaper.
Edit: Stupidly forgot to say that the third party labels feel no different to the Dymo labels adhesive strength wise. I use them to label ESD storage containers and steel racking mostly.
They're slower to type on but nothing quite beats the oldschool embossing machines imo:
