- 19 Sep 2019
Specs:Gigabyte Aorus Gaming 5
9900KF
16gb 2666
Overclock is Dynamic
Vcore LC High
AC Loadline 1
DC Loadline 1
Straight to the fix, is there a way to set a minimum vcore whilst also setting a max Dynamic vcore?
My problem is I'm stable at 1.2v & lower during Prime 95 Small FFT's @4.8ghz for my day to day overclock whilst allowing vcore & mhz to drop according to usage. My issue is when at idle or during light loads like Youtube I get randoms BSOD. Recon its a low volts crash.
Secondly I tried to set AC/DC Loadline back to 0 but noticed my VID core would hit over 1.5v. If memory serves me right you can ignore VID core when using static and just use vcore readings but when running Dynamic VID is an issue and has to be monitored as it can fry your chip. Am I right or wrong on this?
Any suggestions would be greatly appreciated. As you know the 9900k's are a hot beast needing taming if you want to overclock and stop you PC catching fire!
P.s Is Prime95 a valid test these days on 9900k or are we better of using Cinebench R20 for instance?
Thank you
9900KF
16gb 2666
Vcore LC High
AC Loadline 1
DC Loadline 1
Thank you
